주요 콘텐츠로 건너뛰기
2020년 10월에 출시된 새로운 iPad Air. A14 Bionic 프로세서, 10.9인치 화면, 새로운 디자인, 전원 버튼에 내장된 Touch ID 센서를 탑재했습니다.
iPad is a bit curved
I accidentally sat down on my iPad and it became a little bent, and I'm afraid of pressing on it the opposite direction and break the screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Can you post a photo of this issue?
Do you carry your phone in your back pocket,?if so Don't do it
It's an 11 inch iPad, so it's highly unlikely the OP carries it in their back pocket. You can sit on anything without having it in your pocket.
댓글 달기
답변 1개
가장 유용한 답변
That's a tough one. On one hand it could be fine for years even with the bend, or the screen could eventually just snap one day out of the blue from the stress; there's just no way of knowing what it will do.
If it was mine personally I would take the screen off and try to straighten it; your instincts are right on the money with regard to not trying to straighten it with the screen in place. Here's the guide you'd need to do that.
iPad Air 4 Screen Replacement - iFixit Repair Guide
Take the screen off then use a straight edge - something like a metal ruler works well - and gently bend the frame until it's straight. I've done this with an iPad Mini my daughter-in-law was given; in her case the screen had already broken but otherwise it was exactly the same operation. Bend it a bit then check top, bottom, left, right, up and down with the ruler to make sure it's perfectly flat in all dimensions; then and only then you're ready to put the screen back on. Make sure you pre-fit the screen before gluing it down; it should slip into place easily without being forced - if you have to make it go in, then you may have to bend some of the edge away from the glass to give it more breathing space.
Of course, there's always a risk that just the act of trying to remove the screen could possibly break it, so keep that in mind when deciding which way you want to go. It's not a high probability, but it could happen so you should be aware of it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Titan Saleh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 48
전체 시간: 851
