Plug logo on battery icon
I change my iPod battery with a generic 550mah battery because the original one is expensive. After i change the battery the battery icon showed me this, what should i do to get a normal battery icon?
좋은 질문 입니까?
좋은 질문 입니까?
@senopatib could be a battery issue. If this battery was discharged beyond the charging threshold it will no longer accept a charge. It could also be that there are issues with the charging cable or the dock connector. Check that one for broken, bend or corroded pins. Of course, you also want to double check your work to make sure everything is properly connected. The other thing you want to try is to charge the iPod with a wall charger instead of your computer etc.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 40
