주요 콘텐츠로 건너뛰기
Repair guides and support for televisions manufactured by Sony.
20 질문 전체 보기
Sony A90J red light blinking 5 times?
I received an A90J "65 that doesn't turn on or show any LED indication at all. I have an identical one that works though, so I swapped the main board, t-con, and power supply from the working one to the dead one. When I try to turn it on, the LED blinks 5 times (and the display never turns on). I've heard that this is most likely a "bad" panel then. What does "bad" specifically mean in this context that it would be detectable by the boards and thus throw up an error code? Would it be fixable?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@vywsss bad panel really means bad LCD driver boards. Those are the long skinny boards that are the first ones that are connected to the LCD panel. They use some ribbon cables that are connected via a special bonding procedure. These boards are not replaceable by the DIY'er or even most pro's due to the way they are constructed.
The 5 blink code of this model is caused by:
Panel ID EEPROM I2C No ACK
(Also panel power failure is a suspect) [P_ID_ERR]
Data corruption in EEPROM[P_ID_ERR]
and referring to the Triage chart for this model the T-con module is considered the primary suspect followed by the panel.
If you still have the back cover open, takes some good pictures of your boards and the interconnect cables. Post those with your Question. That way we can see what you see.
If it is your panel, you can try a Tape-Off. Essentially that means you isolate some of the data lines on the ribbon cables going to the driver boards. There are plenty of videos on YT that will tell you how to proceed.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
@oldturkey03 Thanks! Unfortunately, this is an OLED tv so I’m not sure how much of that would apply here. Do OLED’s also have a driver board that might be the culprit?
@vywsss you are 100% right. Revised my answer to reflect my oversight :-)
@oldturkey03 Added photos to my question. I might just try going for a new t-con board just in case it works. Are they replaceable on the A90J? I've heard they may be a software lock or something between the original panel and t-con.
@vywsss
I have the exact same problem. Did the t-con board replacement fix the issue?
@kenny01 Unfortunately it didn't. My issue seemed to have been with the the connections to the panel itself, as when I pressed on the bottom of the screen on the line, it began to fade somewhat (but never completely disappeared). The connections on the bottom of the panel are basically inaccessible on oled tvs as far as I'm concerned, so I didn't bother attempting a repair. I assume that the t-con could still be suspect for some other cases but not mine sadly.
댓글 달기
답변을 추가하세요
vywsss 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 65
전체 시간: 842
