phantom clicking in Anywhere MX 3
Same problem addressed for Anywhere MX mouse, but since this model is different, I wonder if there's another solution.
This happened after around 1.5 years of use.
My partner has the same mouse and the same problem, using a different OS, so it seems to me to be a hardware problem.
좋은 질문입니까?
댓글 4개
Hi @glicerico
What had you tried? had you tried replacing the micro switch?
Augustine 의
No, I don't know what the micro switch is or how to replace it. Is there a guide? If you are referring to the article I linked, I planned to do it, but saw in the comments that some people tried with the Anywhere MX 3 and didn't work for them
glicerico 의
Ah, I think the micro switch is the module containing the clickable part. No, I didn't replace that, I don't have the spare part.
glicerico 의
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
Alexandre Abreu 의
