주요 콘텐츠로 건너뛰기
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
29 질문 전체 보기
Can I swap the LCDs of this laptop to a Acer V5 431?
Can i swap the LCDs of these two?? An Acer E14 and Acer v5 both has the same screen size but different connectors. The E14 has 30pin for it's LCD while V5 has 40 pin i was thinking if its okay if i also move the flex connector as well is it possible??.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @markangcos
You can't just interchange 30 pin LCD screens and 40 pin LCD screens that easily.
The panel's operating specifications e.g. LCD panel's operating voltage (Vcc) value, backlight enable voltage signal value, LED power requirements and LVDS cable wiring pinout connections were chosen as these will work with the motherboard that the panel was originally connected to.
If you wish to check what these are, search online for (insert make and model LCD panel¹) datasheet for both LCD panels, to hopefully find them.
If you do find them, then they will have the specifications for the panels so that you can compare if they are the same or not.
If their operating specifications aren't the same, then it won't work and if you try anyway you may end up damaging the LCD panel, the motherboard or both.
If it is only the wiring pinout connections that are different you may be able to adapt the cable so that LCD panel pinout matches the LVDS connector pinout on the motherobard that it is going to connect with.
¹ Usually the make and model number of the LCD panel can be found on the back of the panel itself somewhere.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mark Angcos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 28
