주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
installed new lcd screen, cant hear anything when someone calls me
I broke my lcd screen so i ordered one off ebay from hong kong. i installed it, color is very light on all screens. the big problem is when someone calls me, i answer, they cant hear anything, i cant hear them. the call comes through on the screen but cant hear anything. everything else works, just light color on all screens. why?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Well, the screen lightness is probably because you ordered from Hong Kong. Always buy from US.
As per the lack of sound, it could be that ribbon #3 is not seated properly. Make sure that all connections are fully connected.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The best way to test this is to use the voice recorder app and make sure that the "speaker" button in the top left corner of the screen isn't enabled - this means that the sound recording will play through the ear speaker.
If you can't hear anything then make sure that ribbon cable number 3 is fully pushed in, I like to use a pair of tweezers to help me and then the blue opening tool to flip down the clamp on the logic board. If you still can't hear anything then you may have a faulty part, if you bought from eBay they should sent you another without a problem - in the UK I pay £15 for the whole mid-frame, ear speaker and home button and I have never had any problems in this price range! I think that's around $20
As for the screen brightness you could try using another LCD to see if you get the same problem. If you do you might have a bent pin on the logic board which requires a difficult repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jera lynn whitlaw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 1,007
