My phone is not charging but charger working
While I connect to the charger my phone is not charged
좋은 질문입니까?
좋은 질문입니까?
@vaishnavidevi could be a bad battery, bad charging circuit or a bad charging port. Having run into this a lot over the last few month, the easiest is to actually replace the charging board. It is relatively inexpensive and replacing it is fairly straightforward. Also, check the flex cable from the charging board (sub_board) to the main board for any tears corrosion etc. Once you have the board replaced I would also replace the battery, since you have the phone open. That way you only have to do that one time.
Since ifixit does not yet have a guide for that, use something like this video to replace the parts.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War one Entropy
이 답변이 도움이 되었나요?
Hello I changed bord and battery but still not charging what I need to do now help me please thank you
@gabrielgab45028 did you check/replace the flex cable from the charging board to the main board?
How it's look 😁? Flat one or thin one
I think it's flat one just ordered to change 😉
gini loh bro kawan kawan
saya punya hp poco x 3pro udah lama dan masalah ini bukan dari flaxsibel ataupun papan board pengencesan harus ganti baru, intinya yang rusak itu ic pengecesan yang ada di board mesin
@vaishnavidevi, In my case it was a loose connector. Remove the back cover and check the cable which connects the charging port with the mainboard. You need to remove the cover of the mainboard around the camera to reach the connector. For details, see the tutorials, e.g. for changing the battery. It shows all the necessary steps.
Good luck!
이 답변이 도움이 되었나요?
Hello, my friend, the problem with your phone is probably from the charging socket or it is dirty and turn it off and on again so that it might be fixed, then clean your charging socket.
이 답변이 도움이 되었나요?
지난 24시간: 7
지난 7일: 40
지난 30일: 179
전체 시간: 7,534
댓글 2개
Hp tidak mengisi
Wardin Tolinggi 의
@wardintolinggi follow the instructions from my original answer. Let us know what you find out.
Translate
@wardintolinggi ikuti instruksi dari jawaban asli saya. Beri tahu kami apa yang Anda temukan.
oldturkey03 의
