How to put belt on the mower deck
how dose the belt go on the mower deck
좋은 질문 입니까?
Mike,
Usually there are two belts. One goes around two pulleys, a front pulley under the motor and one on the mower deck. Additionally, there is usually a spring tensioner pulley that rides against the belt to allow it to work and for ease of routing.
The second belt goes under the first belt and is routed on a common pulley with the drive belt and both (or all three) of the mower blade pulleys.
Here is a crazy looking exploded view of a craftsman mower deck
And here is a better diagram of it all put together. I think you can get an idea of belt routing out of this one:
해당 답변은 도움이 되었습니까?
Do I have to bend the metal bracket that keeps belt from slipping off pulley to put a new belt on. The belt will not go on pulley unless I do bend it back.
The bracket that holds the blade belt on the pulley is stable and will not move. How do I get the belt on pulley without bending it
24 시간 전: 26
7일 전: 122
30일 전: 516
전체 시간: 61,375
댓글 6개
how to put blade belt on modile 917289031.
cynthia 의
What about 3 belt craftsman.I have 2 ride mowers one is 2 belt other is 3belt ?? The deck belt patterns are different
Vincesnowgren 의
is this for a deck on a 7000 series 42" cut mower?
gary 의
This is. For the 2ooo series. Model 247.288852. Serial # 1A192B10186
Vincesnowgren 의
46 inch deck
Vincesnowgren 의
댓글 1개 더보기
