Infinite restart loop issue on windows 11
How to solve the infinite restart loop issue in my Lenovo IdeaPad gaming 3 15IHau6 laptop please help me to solve me the issue
좋은 질문입니까?
좋은 질문입니까?
Hi @geninhacks
Try the following and see if that resolves the problem.
Start the laptop and when it starts to boot into Windows, press and hold the Power button to force stop the laptop.
Do this 3 times in a row i.e. Start → boot → force stop → Start → boot → force stop → Start → boot etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menus.
If it does then select Troubleshooting → Advanced → Startup repair and follow the prompts.
Note: Do not select Reset this PC because if you choose the wrong option after selecting this you may erase all your personal data as Windows will be reinstalled.
이 답변이 도움이 되었나요?
I tried it already it's doesn't work
Create a W11 usb recovery disc and boot the laptop using it and repeat the procedure above.
You can create a USB recovery disc from any known working W11 PC.
In the host PC go to Control panel → Recovery →create a recovery disc.
You will need an 8GB USB flashdrive and ~40-60 minutes of time to do this.
Once done insert the USB into the laptop, on startup change the boot order to USB first boot option either using the function key or in BIOS.
지난 24시간: 3
지난 7일: 13
지난 30일: 27
전체 시간: 733
