주요 콘텐츠로 건너뛰기
1.8 또는 2 GHz G5 프로세서
20 질문 전체 보기
Help! My mac 'Pops' off at switch on!
My white un-web cam iMac takes four attempts to start up, making a 'pop' noise when failing, but then works well although can 'pop off' when woken from a long sleep.
Is it a bad power unit?
Please help!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Yes, My first guess would be the power supply. Lay it down flat on its screen.. remove the back.. usually if a power supply is "popping" it will have a distinct smell.. also looks for any buldging or swollen capacitors.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
I'm pretty sure it's the power supply because the original power supply that comes with this model is notorious for failure after long use.
댓글 달기
Could be, but could also be a bad hard drive, use disk utility to verify your hard disk if that's failing, a failing drive can make popping noises.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Big Dan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 2,166
