주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson EcoTank L3150 Wi-Fi 올인원 잉크 탱크 프린터
Scaner dosnt work , it's stick.
When i pick to scan , they scaner makes a sound like it's being stuck ando don't make the copy.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
See for any paper jams etc, Head cleaning, ink charging, or ink drying is in progress. Check to see if the Pause light is flashing.
댓글 달기
답변 1개
선택된 해법
That is common problem for this type (l3150, 3110, 3210) this problem cause by:
  1. Improper scanner attached to its pin.
  2. Hard stuff/heavy stuff felt down on to the scanner.
  3. Dust accumulate on the scanner tract.
Solution:
  1. Check ribbon scanner cable, whether it is torn uuo or not.
  2. Dissemble the scanner and clean the track, while repositioning the scanner correctly (don't miss even half millimetre).
Hope this will answer your questions.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Nahum Alejandro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 760
