주요 콘텐츠로 건너뛰기
Is it possible to replace the hard disk with an SSD?
I would like to clone the current HDD with an SSD to make it faster.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@piero90 yes, you can. Now, with that said, it will depend on what motherboard/processor you have. If your motherboard does not have an M2 slot, you will need to get a 2.5" SATA3 SSD. Something like a Kingston’s KC600 would work
If it does have an M2 use the appropriate SSD for that.
"Support for 6.35-cm (2.5-in) SATA hard drives in 7.0-mm (.28-in) and 9.5-mm (.37-in) thickness Support for M.2 SATA storage (Port 0) (models with i7 processors and 4 GB discrete graphics memory only)" from the HP Envy Maintenance And Service Guide. Page 55 shows you how to check it out and to work on it.
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
Is the following docking station good for cloning laptop HDD to SSD?
https://www.amazon.it/Inateck-Dual-Bay-f...
@piero90 I have not use that particular one but use a similar setup daily without any issues.
@piero90 Looks like it should work, 2TB :-) Awesome!
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Piero Sabino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 137
