주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Realme C3는 Realme에서 개발한 저가형 Android 스마트폰입니다. 2020년 2월 인도에서, 2020년 3월 필리핀에서 출시되었습니다.
Why does my phone continuously switch off and switch on
I can't use my phone cause it starts switch off and swich on till bettry gtes completely empty
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개
My phone switch button not working
의
Display change
의
Family display change
의
댓글 달기
답변 4개
가장 유용한 답변
@bhavikrathod could be a bad battery issue. Make sure that it is fully charged and if it does no longer hold a full charge, replace it. Since iFixit does not yet have guides for this use something like this video Now, with a new battery and if it still is doing this, Try to start your phone in safe mode.
  1. Turn off the device
  2. Press and hold the power button until the Realme logo appears
  3. When the Realme animation logo screen appears, quickly press and hold the volume down button and power button until the device reaches the power-on process
  4. Safe mode will appear on the lower left side of the screen in a transparent style
If it has stopped to turn on and off in safe mode, you know that the issue is related to a bad third party App. You will have to delete one after the other until you know which one it is.
If none of this works, you may have to try a factory reset. This will not work if your phone continue to turn on and off. For the How-to on that use the information from here
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Phone switch off on
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Here's what you can do:
  1. Check for software updates.
  2. Restart your phone.
  3. Boot into safe mode to check for app issues.
  4. Inspect for physical damage.
  5. Consider a factory reset.
  6. If the problem persists, it might be a hardware issue. Contact Realme support or visit a service center for assistance.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
@tabathakang you continue to prove that you are missing the point of this site. I can't figure out if this is based on purpose or if it is based on your AI usage. AI doesn't care, I get that. You as the owner of the answers, should care. Those are your responsibilities.
Let me explain to you what is so fundamentally wrong with your answers. Your AI is not explaining anything. Ask yourself if you could fix a single device by following your answers. You know you couldn't. AI is not explaining how to check for updates, how to restart, how to boot in safe mode, what physical damage to inspect or even how to do a factory reset. You are providing a lot of BLAH BLAH BLAH but nothing even remotely helpful. Train your AI and stop using Google and Bing as the source. If you can't train it, don't use it! WEAK! Very Weak.
=== Repair is War on Entropy!!!! ===
의
how to fix how to fix my on off button not working what should i do
의
@khemirkhal50165 try the solutions mentioned in the Answer. Let us know what, if anything, worked.
의
댓글 달기
Software kasa mara
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bhavik Rathod 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 41
전체 시간: 2,137
