주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
Why is my laptop not charging when I plug it in?
My laptop is not charging when I plug it in. I've tried plugging in and out the charging port, and I tested the charger with another laptop. There's no visible damage on the charging port either, it seems perfectly fine. The light isn't lighting up on the charger, even though it does on the other one. What could be wrong?
Update (05/04/24)
It ran out of battery ages ago. Also, the display wire, hinges and clutch cover are broken.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 14개:
@hamzas Is it fair to assume it is not starting up when connect to a Magsafe power adapter?
@oldturkey03 yes, it doesn't start up when connected to a magsafe power connector
@hamzas So three is absolutely no light (no Amber or no Green light). No sign of life when you plug it in etc.? The MBA appears to be totally "dead"?
@hamzas let's see if a different Magsafe will work for you :-) keeping our fingers crossed but still having some major doubts. There just seem to be a lot going on with your MBA
댓글 9개 더보기
댓글 달기
답변 1개
When you plug in the MagSafe charger does the connector LED lighting up, if it is what color is it Amber or Green?
이 답변이 도움이 되었나요?
점수 0
댓글 7개:
No light at all
@hamzas - Do you have access to a second charger? As it’s either dead or the MagSafe Port’s dirty or bad being the most likely issue.
Yes. none of them are working with the mba. I know they work because I have a 2012 unibody mbp i tested them on.
Thanks for the help. I'll try it and see if it works
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Hamza Safdari 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 225
