주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jeep Cherokee(XJ)는 1997년부터 2001년까지 Jeep에서 제조 및 판매한 소형 SUV입니다. 기존 풀사이즈 SJ 모델의 이름을 공유하지만, 전통적인 바디 온 프레임 섀시가 아닌 경량 유니바디 설계를 특징으로 합니다.
Alternator not charging battery
I have installed new battery and alternator , new belt , replaced new battery cables negative and positive with new ends and cleaned and sanded all the grounds, only getting 12.48 volts at battery and alternator wires, Green/ orange wire from alternator to PCM 12.48 while running, could the PCM be at fault? There is no voltage drops either, tested with multi meter!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@derrick8834 have you scanned the OBD_II. If the PCM receives either under or over voltage, it will pop a code. Something like a P0562 or P0563
The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground. So yes, it is possible that this is strictly PCM related.
Since this is a new alternator, we are going by the assumption that the output voltage is proper. You may need this Charging System Besides checking all the wiring and the bulkhead connector, check fuse F22 in the power distribution center. There is also a fusible link in the wire (Black/White) from the alternator to the battery. See if that has continuity
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Derrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 9
전체 시간: 359
