no signs of life, no boot no led nothing
cant get it to work and it shows no signs of life
좋은 질문 입니까?
좋은 질문 입니까?
@binqy something like that, you will have to start from scratch. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First, you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter (yes, you can get those for barrel adapters as well) and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Of course, it is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Let us know how things are working out with each check/test.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 2
30일 전: 6
전체 시간: 18
@binqy we need to make sure that your Asus is indeed a X54C. Please verify this for us.
oldturkey03 의
