주요 콘텐츠로 건너뛰기
The Acer Aspire 1 A114-31 is an entry-level laptop designed for basic computing tasks. It is lightweight, affordable, and features a fanless design for silent operation. This page provides repair and user manuals for users who need to fix common issues of Acer Aspire 1 A114-31.
10 질문 전체 보기
Why is my laptop not charging
why is not loghiting and it deos not charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @juniorcabane
Use a DMM (digital multimeter) to check if there's 19V DC on the output plug of the charger. If you don't have a DMM then try using a another known working, compatible charger and check it works OK when charging the laptop.
If the charger is OK then here's the video that shows how to open the laptop that may help.
At this stage all you need to do is to locate and unplug the DC-In jack cable (example only) from the motherboard and then use a DMM to check if there's 19V DC when measuring between the red and black wires on the cable plug, with the charger connected to the jack as per normal.
If there is no voltage detected then the jack is faulty and it will need to be replaced as it cannot be repaired. Search online for Acer Aspire A114-31 DC-In jack to find suppliers that suit you best.
If the correct voltage detected, then the schematics for the motherboard would be required to find out what's wrong.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Junior Cabane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 55
전체 시간: 558
