주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Western Digital My Passport Ultra는 500GB부터 최대 5TB 용량까지 제공하는 USB 3.0 휴대용 저장 장치입니다.
Prying open hard drive
Hello - the actual external hard drive I have is a Western Digital easystore 2TB hard drive. The reason I chose the My Passport Ultra is because its practically the same size, form and shape as the easystore EXHD I have. Unfortunately earlier this year when I was getting my new computer all setup, I dropped this hard drive of mine on the floor as it was on top of the CPU. Now, the hard drive just makes a clicking noise every time I plug it in. I wanted to see if there was a way I can extricate the hard drive itself from the case and use a recovery reader I have . However, it seems impossible to do with no way to slither my way through the edge of the hard drive casing.
이미지
Thank you
-Jordan
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
That's fairly risky if it is your first time. there will be tutorials available online. since it can be risky make sure to clone your drive before hand. a lot of free tools out there. you can use Remo Free Disk Clone Software if you want a fast and effective option.
However, I would insist that you simply just take it to a shop as a lot could go wrong here.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@jordan18927 yup, same tabs. You may just need to change the "angle of approach" and a bit more rigid tools. Check on here for the how-to proceed. this is just an example and not an endorsement
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jordan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 82
전체 시간: 1,749
