주요 콘텐츠로 건너뛰기
Introduced in 2021, the Lenovo ThinkPad L14 Gen 2 is an entry level ThinkPad. It features a 14 inch 1080p screen, 16GB of DDR4 memory, a PCIe SSD, two USB-C ports, a Side Docking Connector, an HDMI port, a 3.5 mm headphone jack, an RJ45 Ethernet port, a MicroSD card port, a NanoSIM slot, and a smart card reader.
Why is my computer running out of power So fast
When I'm done charging and then I left it tomorrow even though I Left it off it keep Running out of power help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @tingwang2013
Seems as though there's a problem with the battery in the laptop.
Create a battery report to check the status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as seen in the report.
For a good battery they should be nearly the same value.
You can work out the condition of the battery as a percentage by using the formula: Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery is <35% you may wish to consider replacing it.
Here's the hardware maintenance manual, for the laptop.
Go to p.70 and then to p.84 to view the procedure to remove/replace the battery in the laptop.
Here's the parts list for the laptop. Click on Select Commodity > Rechargeable batteries Internal(8) to find the spare part numbers for all the batteries that are compatible and can be used in the laptop (one of these numbers may also printed on your battery). Search online for the part number only to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
is at 56% so do i replace it or no?
@tingwang2013
You initial post was from 9 months ago so presumably the battery has been working reasonably well since then?
Try fully charging the battery i.e. 100% (check using the battery report that it is 100% or whatever it says when it stops charging) last thing before closing down for the night and then when you next start it see what charge % is shown.
It may be that the battery is self discharging too fast (a good battery shouldn't self discharge that fast, maybe only 1%-2% overnight)
If it loses a lot of charge overnight replace it as it isn't going to get any better, only worse.
댓글 달기
It could be because of your OS settings, if on Windows, check if your power plan has fast startup enabled and if you have been properly turning off the laptop.
If on Linux, check the same, but it could change where depending on your desktop environment,
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
how is that Related to anything?
댓글 달기
답변을 추가하세요
tingwang2013 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 20
전체 시간: 268
