주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
많은 Packard Bell 컴퓨터에 사용된 4X4 데스크톱 케이스입니다. 전면에 있는 2개의 5.25인치 드라이브 베이로 쉽게 식별할 수 있습니다.
operating system not found?
operating system not found ?? i have checked all of the drives sepearttly, they seem to work.. but the 1994 packard bell says operating system not found. i have tired to boot from a floppy, and it tells me to remove disk and continue.. then i get diddo operating system not found, i am stumped..
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
i have tried to reset things in the bios, and it perfers to load defaults, i had upgraded the dead battery, so it keeps current time,,
의
Hi @gerryfranc26930
Intrigued by your question as I've never heard of a Dido OS if this is what you mean.
If it is then looking at this it seems that it is a program designed to work on Windows (or Linux) and not a separate bootable OS but maybe I misinterpreted it.
의
댓글 달기
답변 2개
May be the os were currepted, try to install os again. It may fix the issue
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hey! Ah, the nostalgia of a 1994 Packard Bell! I remember having a similar issue with an old PC I was trying to revive. It can be super frustrating when it keeps saying "operating system not found."
One thing that worked for me was checking the BIOS settings to make sure it was set to boot from the correct drive. Sometimes, these old systems can reset their boot order for no apparent reason. Also, double-check if the hard drive connections are secure.
When I was troubleshooting my old machine, I stumbled upon some great advice on operatingsystems. They had some tips for dealing with vintage hardware issues that were surprisingly helpful.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gerry Franco Roberts 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 40
전체 시간: 374
