Not cooling only giving hot air
좋은 질문입니까?
Which type of AC is it, in generally if it is not cooling then either it might be that mode has been unknowingly changed on remote control or there might be a refrigerant leakage problem
이 답변이 도움이 되었나요?
Bruhm ac is not cold
The steps are as follows
1 Check the remote control to make sure you set it correctly
2 Make sure the outdoor and indoor unit is clean
3 Check the capster, the outdoor unit if it has leakage or swelling, it is damaged, and to make sure more, examine it through the multimeter
4 If the capster is excellent, turn on the air conditioner and note the outdoor unit if it works excellently (compressor works sound), here check the freon
5: If it does not work or the compressor does not take off, check the so-called external relais from the pressure on it. If you press it and it works, the defect is from it, and if you press it and the air conditioner does not work, the defect is from the compressor
6 Unscrew the compressor wires and check with the multimeter by connecting the compressor to one end of the compressor and the other end to another part
Thank you
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 27
지난 30일: 68
전체 시간: 1,066
댓글 4개
My ac not cooling
chanakya pawar 의
My Ac is giving hot air
Ali Haider 의
@alihaider55490
Please confirm the make and model number of your air con unit?
Can you hear if the compressor motor is running or not?
jayeff 의
Only hot air
Hassan Hh 의
