주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Do I have a defective battery?
I have a MacBook Core Duo and it recently told me to service the battery. When I looked in iStat Pro I saw that I had 126 charge cycles and 60% health. I calibrated the battery and it stayed the same. I have only had the battery for about a year and a half now and I know that you shouldn't have it plugged in for a long time. I charge it then leave it unplugged until it gets to 10% and then I charge it. The reason why I ask if it is defective is because my neighbor has a battery in their Core Duo MacBook that is original to the computer with 745 cycles on it and it has 75% health. If you think it is defective then do you think I could get it replaced by Apple under a manufacturing defect? Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
To get a good idea of the health of your battery, download, install and run "Coconut Battery". http://www.coconut-flavour.com/
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
I previously downloaded this app to get more detailed information on my battery and it told me that the full capacity is supposed to be 5198 mAh but I only have a max of 3125 mAh with a full charge. It also says the battery is 1.6 years old and has 128 charge cycles. Right now I am using the laptop and it has 36 min of time left with a 54% charge and idle.
댓글 달기
귀하의 답변을 추가하세요
Owen Cunneely 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 710
