주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Which graphic card support?
In this dekstop which graphic card is support???
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@soumenmaji there are actually quite a few but these are the common ones:
GPU upgrade options for Lenovo ThinkCentre M82 Tower with the stock 450W power supply
GPU Power consumption Memory Req.
NVIDIA GTX 1660 Super 130 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1660 Ti 125 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1070 145 W 8 GB DDR5 *Dual SATA to PCIe adapter
NVIDIA RTX 3050 130 W 8 GB DDR6 *Dual SATA to PCIe adapter
  • Typically, the stock power supply in a business PC does not have the necessary 6 or 8 pin connectors to power the GPU. In such cases, you may need to use a low-power GPU or a SATA to PCIe power adapter. Alternatively, you can change the entire PSU. from here
To work on your Lenovo use this ThinkCenter Hardware Maintenance Manual
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
SOUMEN MAJI 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 36
전체 시간: 467
