55pus6262/12 does nothing, but gets power.
Hello,
Thank you for taking the time to look at this question. I was cleaning around my TV, Moved it and cleaned only on top of the tv and with a damp cloth not wet went aross the front bottom part of the tv so the edge between the screen and the trim. After placing it back the TV would not turn back on, the normal red light indicator does not turn on at all. This would indicate a power issue, so i tried the cable with tv around the house and the plugs that do work for other things like charging my phone don't work for the TV.
Checked the end of the cable that goes into the tv with a testing screwdriver and its lighting up so it gets power. I opened up the TV and i see the board where the power comes in and a fuse, so plugged the powercable in and checked both sides of the fuse and both sides lit up the screwdriver so it got power.
Now i am at the end of what i can test. If i could attach pictures i would. Maybe i have the option later.
Thank you and i hope to figure it out as i dont want to need to buy a new tv as this one was working perfectly
좋은 질문 입니까?
