주요 콘텐츠로 건너뛰기
Repair guides and support for the Huawei Mate 9, an Android smartphone first released in November 2016.
20 질문 전체 보기
Battery Charging Status Abnormal
How do I resolve the issue where my battery does not charge above 60% and brings a notification like Battery Charging Status Abnormal...??
Tried replacing faulty battery still not resolved tried different chargers, nothing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
@wangumwanza the only other obvious thing to try would be to replace the sub board (daughter board) and to check the ribbon cable going from the sub board to the main board. If after replacing those you still have the same issues, then you will be looking toward a board-level repair. Huawei Mate 9 Teardown
If nothing else, take a look on here and see if that helps you after those two other things I would try first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
it's not the battery, it's a bug in the update of EMUI software. Huawei misleading users instead of fixing it.
Backup your phone first, then downgrade to previous version software. problem will be resolved 100%. do not let the phone update automatically
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wangu Mwanza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 14
전체 시간: 104
