주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Do I need to replace partially torn audio jack cable (interior)?
While doing a combo power and sensor cable/dock connector repair (I tore the dock connector completely while peeling it back) I noticed a small half-tear to the black cable attached to the audio jack that connects to the logic board. Will this function in its current state or do I need to replace it?
Here's the picture- http://i1015.photobucket.com/albums/af27...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Tom, I would suggest that you fix what is broken. I would honestly not expect it to work if it does not get replaced/repaired. Broken, even partially broken, parts usually cause you more trouble later on. Replace it now and be done with it. :-) Just my 2 cents, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the advice. Also, do you think you could take a look at this question? I'm having trouble with the front-facing camera. iPhone Front camera won't fit into place..
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 324
