주요 콘텐츠로 건너뛰기
10월 13일에 발표되어 10월 23일에 출시된 Apple의 2020년 플래그십 스마트폰은 6.1인치 OLED 디스플레이, LiDAR가 탑재된 트리플 렌즈 후면 카메라 시스템, 5G가 특징입니다. iPhone 11 Pro의 후속작입니다.
What part contains the mic?
Need to replace my microphone but I don’t see it listed anywhere. What part includes the mic?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You are going to have to be more specific; there are three microphones on the iPhone 12 Pro model, depending on what you're doing.
The one primarily used on phone calls is located at the bottom of the phone and is mounted on the charging port assembly.
A second microphone is used when you're on speakerphone or using the selfie camera and is located on the earpiece speaker assembly mounted on the display.
The third one is on the rear side of the phone in the middle of the cameras, and is mounted on the flash assembly.
In each of these images the microphone can be seen as a small gold-colored rectangle.
You should be aware that replacing the earpiece speaker assembly will cause you to lose Face ID. There should be no issue replacing any of the other microphones.
Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627. 이미지
제품
iPhone 12/12 Pro Lightning Connector Assembly
$26.99
Fix a malfunctioning flash with this replacement assembly. 이미지
제품
iPhone 12 Pro Flash Cable
$29.99
Replace an earpiece speaker or sensor assembly compatible with the iPhone 12 and 12 Pro models A2172, A2402, A2403, A2404, A2341, A2406, A2407, A2408. 이미지
제품
iPhone 12/12 Pro Earpiece Speaker and Sensor Assembly
$32.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
chevroleddie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 118
전체 시간: 1,343
