Why is my HP 15t laptop not powering!
It indicates there's power input. It switches on, then goes off immediately
좋은 질문 입니까?
좋은 질문 입니까?
@toyin239 you are not telling us how it indicates that it has power. If this happens on AC as well as battery power, it appears as if you have a short circuit issue somewhere on the power circuit or a bad processor. Start of with the Maintenance And Service Guide for your computer.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
Of course, it is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 4
