주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Phone will not power on or be recognized on computer. Fix?
So I have an iPhone 4 that will not power on or be recognized in a computer. I removed the battery and plugged the phone up, but no response. I ordered and replaced the dock connector. but still didn't get a response. Does it have a bad logic board or is there something else that I can try?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Replace the battery. If that does not help, it's probably the logic boarfd.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Curtis
Have a read of this post
Will not power on, what could it be?
This post I believe gives you good recommendations to start of. Also have a look at the logic board and see if you can notice any corrosion, if so do a isopropyl alcohol solution bath to help loosen the corrosion and using a soft bristle brush like a soft toothbrush lightly brush the corrosion off. The alcohol bath will also help remove any kind of moisture that may be on the logice board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 507
