주요 콘텐츠로 건너뛰기
The Lenovo ThinkPad X1 Carbon 8th Gen comprehensive repair guide is designed for students, professionals, and technicians. It provides detailed steps for troubleshooting and efficient problem-solving.
4 질문 전체 보기
How I can change ram
i want to replace ram
and want to upgrade 8 gb to 16 gb
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @adnanhassan
The memory is hard mounted on the systemboard and cannot be replaced.
To upgrade the amount of memory you would have to replace the systemboard.
Here's the hardware maintenance manual for the laptop. Go to p.86 to view the procedure to remove/replace the systemboard.
Here's the parts lists for the MT 20U9 and 20UA models, that may help. (check for the MT number on the product information label on the bottom of the laptop).
Click on Select Commodity - System Boards (110) to find the part numbers for the 110 different systemboards that are used in the laptop. If you click on the Specs link in each part you'll see the relevant specifications of the motherboard.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adnan Hassan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 75
전체 시간: 326
