주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 또는 3.5 GHz Core i7 프로세서, ID iMac14,2
20 질문 전체 보기
How to best diagnose a dead screen vs. the graphic card
I have a 2013 iMac 27" which suddenly started to display a blank / black screen. It is definitely running as I can hear the chime at power on and the fan and hard drive making noise. I have tried to boot into reset / diagnostic mode and check that the ram was seated correctly, still nothing.
I should mention that an external monitor will not work either and is the reason why I question if it is the screen itself or the graphic card...
What is are there best methods to diagnose the graphic card vs display? Can I run any diagnostics without removing the screen?
Thank you,
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Does the screen change at all when you power it on? Sometimes it can be hard to tell, but if you're getting a backlit black screen, then the display itself is probably still working fine. It's pretty rare for the GPU to fail on the 2013 27-inch iMacs, so I'd be surprised if that was the case. Sometimes a failing internal hard drive can cause the symptoms you're describing, though, especially a failing Fusion Drive. Unfortunately I think the only way forward at this point would be to open up the device and test the internal components. Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jayson Wonder 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 23
