주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
problem SSD upgrading MacBook Air
I bought SSD drive "Toshiba THNS128GG4BMAA for apple macbook air Rev B&C" (Ebay)
I installed it into my MB543LL (late 2008) instead old Samsung HDD. But Apple disk utilites does not see this drive and i can not format or install OS
Is there a way to make this SSD visible by Apple disk utilite ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
i find answer myself. This SSD must be connected by inverted hard drive cable
댓글 달기
답변 3개
선택된 답변
The drive is probably a 3GB and needs to be slowed down to 1.5 GB to be seen. See if the drive has jumper pins and try 1&2 or 3&4.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
is there a jumper on this SSD ?
I don't know, look at it.
no jumpers on Toshiba THNS128GG4BMAA
Contact Toshiba to see if it can be slowed down or if it is compatable: http://www.toshiba.com/tai/support_consu...
댓글 달기
Were you able to find a cable that will work with that drive?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you can use the same original cable. Just flip hdd to connect (Toshiba THNS128GG4BMAA must be connected not like original hdd) - inverted
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,959
