주요 콘텐츠로 건너뛰기
Removing scratches from the back?
I got a iPod nano for 10$ and it does work, but it is scratched up like mad on the back
Is there anything i can try to to remove some, if not all of the scratches?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Nick, what I do with the older back plates is to use some buffing compound and a buffing wheel. This usually removes most scratches Depending on how deep they are). Your Nano is a bit small and tough to hang on to, so be careful if you use a wheel. Otherwise you will have to buff it by hand. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
Most of them are the light ones that are pretty typical on shiny back iPods, a few lighrt scratches
Yes, they should buff out.
i'll have to try it and get a case to avoid this again, although it's commonplace, i do want to keep it minimal
Thanks for accepting my answer. Yes, a case would be good, since they do get banged up quite a bit. Good Luck.
this one has dings on the faceplate from being dropped, and scratches too, pretty clear old owner, who was a friend never used a case
댓글 달기
답변을 추가하세요
Nick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 8
전체 시간: 1,646
