주요 콘텐츠로 건너뛰기
iPod Original, Mini, Shuffle, Nano 및 Touch를 포함한 대부분의 iPod 전체 분해 및 설치 안내서.
6217 질문 전체 보기
How to use iPod Diagnostics
How can you troubleshoot what is wrong with a broken iPod other than just swap out the parts that you guess are broken based on symptoms? Can you use the diagnostics menu to pinpoint a say bad hard drive or bad hard drive and motherboard or bad clickwheel etc. Does apple have a machine which does the diagnostics? Thanks for any info
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
every time i do9wn load my iPod music it only downloads my sons and it is hae ing trouble with my Playlist
댓글 달기
답변 4개
가장 유용한 답변
to enter the special diagnostic mode, you need to force a hard reset, then after the Apple logo appears you press another special button combination.
here's a quick graphical representation on the special button presses to get your iPod into the hidden diagnostic mode (along with the buttons to get it into disk mode or to reset your iPod)
The buttons you need to press vary depending on the model of iPod.
some further info on the various tests within diagnostic mode can be found here
basically once you press the required buttons, you should hear a beep and see a couple menu choices for auto or manual tests.
NOTE: some of the tests require you to connect a USB and FireWire cable, and the test may seem to be stuck until you do so - therefore I recommend you use the manual mode and only select the appropriate tests.
You can use the diagnostics to check for basic function of I/O, Flash and SDRAM memory, power circuits, scroll wheel and buttons, etc. There's also an LCD display test that fills the screen with solid colors, and you can confirm logic board version number and other system config info.
some models of iPod will let you do a hard disk scan test. But even models lacking the full HD scan test will let you check the SMART status of the drive (of course, assuming it's a hard drive based iPod)
Check out the links I mentioned above for more info.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
The second link in this post "diagnostic mode can be found here" directed me to malware
second link is dead
댓글 달기
Well, provided it's not an iPod Touch, there are diagnostics built-in. To get into them, you need to reboot the iPod (Menu + Select), then hit previous + select. Through running the diagnostics, it should be able to tell what's wrong.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I've been to the diagnostics menu many times I'm just not sure what to make of what it tells me. For example could I test for a bad HD? how?
댓글 달기
Well it's true there's built in diagnostics, but unless you really know what you're looking at, it can be kind of tricky.
Try this to test your hard drive:
HDD test
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Link is dead!
댓글 달기
my 10 year old iPod Classic is being stubborn since last week and now it down loaded you music files no problem but soon as it got to my play list it is stooping and starti9ng on its own
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Dead HDD my guy
댓글 달기
귀하의 답변을 추가하세요
quinnGoes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 91
전체 시간: 38,279
