주요 콘텐츠로 건너뛰기
Repair and information guide for the Whirlpool GI6FARXX**, a bottom-freezer refrigerator released in 2010, featuring an automatic defrost system and an anti-sweat heater switch. This page covers information for model numbers matching the pattern GI6FARXX**.
Water dispenser from GI6FARXXY08 runs randomly
Water filter sporadically runs leaking on floor The water dispenser is running sporadically and leaking on the floor.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @herpherp
Regarding the water filter leaking, here's a video that may help. Here's a video that shows how to install a filter bypass, (p/n W11395888) that was mentioned in the first video.
If the fix in the first video doesn't work due to a worn filter head you may have to replace the water tank assembly p/n W11346622 as the filter head is a part of it and not a separate component.
The leak in the dispenser may be due to a faulty spigot p/n W11227371.
Search online for the relevant part numbers to find suppliers that suit you best.
This reservoir is a genuine part for Whirlpool dryers, designed to address functionality issues. 이미지
제품
W11346622 - Whirlpool Dryer Reservoir
$91.99
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Ok tried those steps thank-you. After about 3 min the water dispenser will turn on and run. So I disconnected the cable again.
@herpherp
If you haven't already done so check that the water tank isn't clogged
댓글 달기
답변을 추가하세요
herpherp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 116
