주요 콘텐츠로 건너뛰기
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
20 질문 전체 보기
My charging port doesn’t work
For some reason my charging port quit working today. I plugged it into my Xbox one a few hours ago and it worked fine. It seems to not register a cable at all, I tried the official cable and my other cable that worked before on my series S as well. Any tips?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Jaycie!
First check the USB-C port for dust. Clean it as much as you can. Try with an tooth pick first. If that doesn't work, you can try with an flathead screw driver carefully! If that didn't solved it, then you need to replace it. Unfortunate you need to desolder the port from the motherboard.
There is a guide here which shows you about removing the motherboard: Xbox One Elite Wireless Controller Series 2 Bumper Switches Replacement
If you have any questions, please let us know!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jaycie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 17
전체 시간: 60
