주요 콘텐츠로 건너뛰기
2023년 10월에 출시된 Google Pixel 8 Pro 스마트폰의 수리 및 분해 정보입니다. 모델 번호 G1MNW(NA/AU), GC3VE(EU, 인도), GE9DP(JP)로 식별됩니다.
Wifi & Bluetooth not working after screen replacement?
Just finished it. Didn't mess with anything. Phone has been broken for like 4 months so haven't used it. Already reset both cell and Wi-Fi Bluetooth in settings. Would love to do a hard reset but I need data to back up device. I haven't fixed fingerprint scanner yet, so curious if that's the issue???
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Hi @jensendash,
Did you mean that you need to backup the device before doing a hard reset?
If so have you thought about backing up your data to a PC via a USB cable?
Update (08/31/24)
@jensendash
The computer idea was only for data backup, not for resolving the WiFi/BT issue. Manufacturers assume that users regularly backup or sync their data to the cloud via the mobile phone network data connection that's why they provide free cloud storage, so generally needing a computer for backup before doing repairs wouldn't be necessary.
If the WiFi and BT both turn on but cannot detect or connect to networks or BT devices try using the phone's WiFi as close as possible to the home network router i.e. <10cm and check if it now detects the network and maintains a stable connection.
If it does then there may be an antenna problem with the phone.
Whilst replacing the screen the WiFi antenna cable may have accidentally come loose from the coax connector (either end)
Unfortunately if this is the case, you will have to disassemble the phone to check.
Here's the ifixit Google Pixel 8 Pro Logic Board Replacement guide that may help. See Step.43 and Step.44 for the antenna cable connections
Did you get an OEM replacement screen? I thought that the fingerprint scanner was a part of the display assembly.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have. But for the same reason I haven't solved the issue with the fingerprint scanner, I don't have access to a computer. I wasn't informed I'd need one when buying a replacement screen either.
댓글 달기
답변을 추가하세요
Jensen Dash 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 28
지난 30일: 117
전체 시간: 1,369
