주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 8 Pro Logic Board Replacement
필요한 것
    1. Google Pixel 8 Pro Logic Board Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Completely power off your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 3개
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
      • Remove the SIM card tray.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 3개
      • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Tape over a cracked screen: 4 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Tape over a cracked screen: 4 단계, 이미지 2개 중 2개
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
      • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Heat the bottom edge adhesive: 5 단계, 이미지 1개 중 1개
      • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
      댓글 쓰기
    4. Google Pixel 8 Pro Logic Board Replacement, Secure the Anti-Clamp: 6 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Secure the Anti-Clamp: 6 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Secure the Anti-Clamp: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
      • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
      • Position the suction cups as close to the center of the bottom edge as possible.
      • Squeeze the cups together to create suction.
      댓글 쓰기
    5. Google Pixel 8 Pro Logic Board Replacement, Twist the handle: 7 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Twist the handle: 7 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Twist the handle: 7 단계, 이미지 3개 중 3개
      • Pull the handle forward to lock the arms.
      • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
      • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
      댓글 쓰기
    6. Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 8 단계, 이미지 3개 중 3개
      • Wait one minute for a gap to form between the screen and frame.
      • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
      • Insert an opening pick into the gap.
      • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
      • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
      • Skip the next two steps.
      댓글 쓰기
    7. Google Pixel 8 Pro Logic Board Replacement, Apply a suction cup: 9 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Apply a suction cup: 9 단계, 이미지 2개 중 2개
      • Apply a suction handle to the center of the screen's bottom edge.
      댓글 쓰기
    8. Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 10 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 10 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 10 단계, 이미지 3개 중 3개
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • If you're having trouble creating a gap, apply more heat and try again.
      댓글 쓰기
    9. Google Pixel 8 Pro Logic Board Replacement, Prevent damage to your phone: 11 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Prevent damage to your phone: 11 단계, 이미지 2개 중 2개
      • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
      • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
      • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
      댓글 쓰기
    10. Google Pixel 8 Pro Logic Board Replacement, Separate the bottom edge adhesive: 12 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the bottom edge adhesive: 12 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Separate the bottom edge adhesive: 12 단계, 이미지 3개 중 3개
      • Slide the opening pick along the bottom edge to separate the adhesive securing it.
      • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
      댓글 쓰기
    11. Google Pixel 8 Pro Logic Board Replacement, Heat the right edge adhesive: 13 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      댓글 쓰기
    12. Google Pixel 8 Pro Logic Board Replacement, Separate the right edge adhesive: 14 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the right edge adhesive: 14 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Separate the right edge adhesive: 14 단계, 이미지 3개 중 3개
      • Insert a second opening pick under the bottom right corner of the screen.
      • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
      • Leave the pick in the top right corner to prevent the adhesive from resealing.
      댓글 쓰기
    13. Google Pixel 8 Pro Logic Board Replacement, Leave a pick in the bottom left corner: 15 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Leave a pick in the bottom left corner: 15 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Leave a pick in the bottom left corner: 15 단계, 이미지 3개 중 3개
      • Insert a third opening pick under the bottom edge of the screen.
      • Slide the new pick to the bottom left corner.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      댓글 쓰기
    14. Google Pixel 8 Pro Logic Board Replacement, Heat the left edge adhesive: 16 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      댓글 쓰기
    15. Google Pixel 8 Pro Logic Board Replacement, Separate the left edge adhesive: 17 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the left edge adhesive: 17 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Separate the left edge adhesive: 17 단계, 이미지 3개 중 3개
      • Insert a fourth opening pick under the bottom left corner of the screen.
      • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
      • Leave the pick in the top left corner to prevent the adhesive from resealing.
      댓글 쓰기
    16. Google Pixel 8 Pro Logic Board Replacement, Heat the top edge adhesive: 18 단계, 이미지 1개 중 1개
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      댓글 쓰기
    17. Google Pixel 8 Pro Logic Board Replacement, Separate the top edge adhesive: 19 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the top edge adhesive: 19 단계, 이미지 2개 중 2개
      • Insert a fifth opening pick under the top edge of the screen, near the left corner.
      • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
      댓글 쓰기
    18. Google Pixel 8 Pro Logic Board Replacement, Prop up the screen: 20 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Prop up the screen: 20 단계, 이미지 2개 중 2개
      • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
      • Swing up the right edge of the screen like the front cover of a book.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      • Prop up the screen so you can access the screen cable without straining it.
      댓글 쓰기
    19. Google Pixel 8 Pro Logic Board Replacement, Remove the screen cable cover: 21 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the screen cable cover: 21 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the screen cable cover: 21 단계, 이미지 3개 중 3개
      • Use an opening tool to pry up the upper edge of the screen cable cover.
      • Remove the cover.
      댓글 쓰기
    20. Google Pixel 8 Pro Logic Board Replacement, Disconnect the screen: 22 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the screen: 22 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the screen: 22 단계, 이미지 3개 중 3개
      • Insert the point of a spudger under the top right corner of the screen's press connector.
      • Gently pry up and disconnect the cable.
      • Remove the screen.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      댓글 쓰기
    21. Google Pixel 8 Pro Logic Board Replacement, Screen information: 23 단계, 이미지 1개 중 1개
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      댓글 쓰기
    22. Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 24 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 24 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 24 단계, 이미지 3개 중 3개
      • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
      • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
      • Reconnect the screen cable and reinstall its cover.
      • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
      • Press firmly around the perimeter of the screen to secure it with the new adhesive.
      • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
      • Follow this guide to calibrate the fingerprint sensor.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the 5G mmWave antenna: 25 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the 5G mmWave antenna: 25 단계, 이미지 2개 중 2개
      • The next few steps show how to disconnect and detach the 5G mmWave antenna cable. If your phone doesn't have a 5G mmWave antenna, skip the next four steps.
      • Be very careful not to scrape off or damage any surface mounted components during this step.
      • Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Heat the 5G mmWave antenna adhesive: 26 단계, 이미지 1개 중 1개
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Separate the 5G mmWave antenna adhesive: 27 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the 5G mmWave antenna adhesive: 27 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Separate the 5G mmWave antenna adhesive: 27 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
      • Twist the spudger to separate the bottom of the cable from the midframe.
      댓글 쓰기
    4. Google Pixel 8 Pro Logic Board Replacement, Peel up the 5G mmWave antenna: 28 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Peel up the 5G mmWave antenna: 28 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Peel up the 5G mmWave antenna: 28 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Tesa 61395 Tape
      $8.95
      • Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
      • During reassembly, press the cable back into place on the midframe to secure it with the old adhesive. If it doesn't stick, use thin, double-sided tape to secure it.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Remove the graphite tape: 29 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the graphite tape: 29 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the graphite tape: 29 단계, 이미지 3개 중 3개
      • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
      • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
      • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
      • Peel up and remove the entire graphite sheet.
      • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Move the USB‑C cover tape: 30 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Move the USB‑C cover tape: 30 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Move the USB‑C cover tape: 30 단계, 이미지 3개 중 3개
      • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
      • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 31 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 31 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Reassembly information: 31 단계, 이미지 3개 중 3개
      • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
      • Remove the larger rectangular liner from the shim.
      • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
      • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
      • Remove the remaining liner.
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Remove the USB‑C port cover: 32 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the USB‑C port cover: 32 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the USB‑C port cover: 32 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      FixMat
      $36.95
      • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
      • Remove the cover.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Unfasten the midframe: 33 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the midframe: 33 단계, 이미지 2개 중 2개
      • Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Remove the midframe: 34 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the midframe: 34 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the midframe: 34 단계, 이미지 3개 중 3개
      • Remove the midframe.
      • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the battery: 35 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the battery: 35 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the battery cable press connector.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the front camera: 36 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the front camera: 36 단계, 이미지 2개 중 2개
      • Use the point of a spudger to pry up and disconnect the front camera press connector.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Remove the front camera: 37 단계, 이미지 1개 중 1개
      • Remove the front camera.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the rear camera assembly: 38 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the rear camera assembly: 38 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the rear camera assembly: 38 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect all three rear camera press connectors from the top edge of the logic board.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Unfasten the rear camera assembly: 39 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the rear camera assembly: 39 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the rear camera assembly: 39 단계, 이미지 3개 중 3개
      • You may need to hold the 5G mmWave antenna cable out of the way while removing the rear camera assembly screws.
      • Use a T3 Torx screwdriver to remove the two screws securing the rear camera assembly:
      • One 3.5 mm‑long 3IP Torx Plus screw securing the top left corner
      • One 5 mm‑long 3IP Torx Plus screw securing the top right corner
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Remove the rear camera assembly: 40 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the rear camera assembly: 40 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the rear camera assembly: 40 단계, 이미지 3개 중 3개
      • Insert a spudger between the right edge of the rear camera assembly and frame.
      • Pry the rear camera assembly up and remove it.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Unfasten the 5G mmWave antenna bracket: 41 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the 5G mmWave antenna bracket: 41 단계, 이미지 2개 중 2개
      • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the 5G mmWave antenna bracket.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Remove the 5G mmWave antenna bracket: 42 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the 5G mmWave antenna bracket: 42 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the 5G mmWave antenna bracket: 42 단계, 이미지 3개 중 3개
      • Insert the tip of a spudger in one of the 5G mmWave antenna bracket's screw holes.
      • Pry up with the spudger to dislodge the bracket.
      • Remove the bracket.
      • During reassembly, insert the bracket at a downward angle so the spring contacts and foam pads press up against the 5G mmWave antenna. Press the bracket down to secure it.
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Remove the 5G mmWave antenna: 43 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the 5G mmWave antenna: 43 단계, 이미지 2개 중 2개
      • Grab the 5G mmWave antenna cable and gently lift the antenna out of its recess.
      • If the cable disconnects from the antenna, don't worry! Use your fingers to remove the antenna. Make sure to reconnect the antenna cable during reassembly.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 44 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 44 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 44 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      $3.99
      • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the top left corner of the logic board.
      • Gently lift straight up to disconnect the cable.
      • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
      댓글 쓰기
    1. Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 45 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 45 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      $3.99
      • Insert one arm of a pair of angled tweezers under the metal neck of the white antenna cable coaxial connector, located on the top left corner of your phone.
      댓글 쓰기
    2. Google Pixel 8 Pro Logic Board Replacement, Unclip the antenna cable: 46 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unclip the antenna cable: 46 단계, 이미지 2개 중 2개
      • Gently pull the white antenna cable out of its clip on the left side of your phone.
      댓글 쓰기
    3. Google Pixel 8 Pro Logic Board Replacement, Disconnect the logic board: 47 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the logic board: 47 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the logic board: 47 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the interconnect and ultra-wideband press connectors from the top left corner of the logic board.
      댓글 쓰기
    4. Google Pixel 8 Pro Logic Board Replacement, Unfasten the loudspeaker: 48 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the loudspeaker: 48 단계, 이미지 2개 중 2개
      • Use a T3 Torx screwdriver to remove the 5 mm‑long 3IP Torx Plus screw securing the loudspeaker.
      댓글 쓰기
    5. Google Pixel 8 Pro Logic Board Replacement, Remove the loudspeaker: 49 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the loudspeaker: 49 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the loudspeaker: 49 단계, 이미지 3개 중 3개
      • Insert the point of a spudger between the bottom right edge of the loudspeaker and frame.
      • Pry the loudspeaker up with the spudger to dislodge it from its recess.
      • Remove the loudspeaker.
      • During reassembly, insert the edge of the loudspeaker with an orange gasket at a downward angle into its recess. Then press the loudspeaker firmly into place.
      댓글 쓰기
    6. Google Pixel 8 Pro Logic Board Replacement, Heat the battery adhesive: 50 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Heat the battery adhesive: 50 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Heat the battery adhesive: 50 단계, 이미지 3개 중 3개
      • Adhesive secures the battery to the frame. Heating the back cover softens the adhesive, making it easier to separate.
      • Carefully flip your phone over and lay it down on your workspace.
      • Use a hairdryer or heat gun to heat the left side of the back cover, where the battery is located. It should be slightly too hot to touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      댓글 쓰기
    7. Google Pixel 8 Pro Logic Board Replacement, Apply isopropyl alcohol: 51 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Apply isopropyl alcohol: 51 단계, 이미지 2개 중 2개
      • Flip your phone back over and lay it on your workspace.
      • Apply a few drops of highly-concentrated isopropyl alcohol along the right edge of the battery.
      • Tilt your phone to help the alcohol flow towards the adhesive on the top and bottom edges of the battery.
      • Wait one minute to allow the alcohol to dissolve the adhesive.
      댓글 쓰기
    8. Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 52 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Insert an opening pick: 52 단계, 이미지 2개 중 2개
      • Insert the flat side of an opening pick between the right edge of the battery and frame.
      댓글 쓰기
    9. Google Pixel 8 Pro Logic Board Replacement, Separate the battery adhesive: 53 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Separate the battery adhesive: 53 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Separate the battery adhesive: 53 단계, 이미지 3개 중 3개
      • Take care not to crease or bend the battery—it can leak dangerous chemicals and/or catch fire.
      • The adhesive securing the battery is very strong. Separating it requires time and constant pressure. It will most likely take multiple rounds of heat and isopropyl alcohol.
      • Firmly secure your phone with one hand.
      • With your free hand, pry the battery up with the pick. Maintain constant pressure on the pick until the battery separates from the frame.
      • If after two minutes of constant pressure the battery doesn't budge, apply more heat and isopropyl alcohol and try again.
      댓글 쓰기
    10. Google Pixel 8 Pro Logic Board Replacement, Remove the battery: 54 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the battery: 54 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the battery: 54 단계, 이미지 3개 중 3개
      • Use the opening pick to lift the battery and separate the remaining adhesive.
      • Remove the battery.
      • During reassembly:
      • If your battery is creased, bent, or deformed, do not reuse it—it's a fire hazard. Replace it with a new battery.
      • Follow this guide to remove the old adhesive and install your battery.
      댓글 쓰기
    11. Google Pixel 8 Pro Logic Board Replacement, Remove the grounding bracket: 55 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the grounding bracket: 55 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the grounding bracket: 55 단계, 이미지 3개 중 3개
      • Use a T3 Torx screwdriver to remove the 2.5 mm‑long 3IP Torx Plus screw securing the grounding bracket to the bottom right edge of your phone.
      • Remove the grounding bracket.
      댓글 쓰기
    12. Google Pixel 8 Pro Logic Board Replacement, Unfasten the logic board: 56 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Unfasten the logic board: 56 단계, 이미지 2개 중 2개
      • Use a T3 Torx screwdriver to remove the 3.5 mm‑long 3IP Torx Plus screw securing the logic board.
      댓글 쓰기
    13. Google Pixel 8 Pro Logic Board Replacement, Remove the logic board: 57 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the logic board: 57 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the logic board: 57 단계, 이미지 3개 중 3개
      • Before removing the logic board, make sure the SIM card tray is removed.
      • Lift the top edge of the logic board and remove it, making sure no cables get snagged on the board.
      • Make sure the interconnect, ultra-wideband, and black antenna cables are out of the way before putting the board into place.
      • Insert the board at a downward angle so the USB‑C port goes into its recess in the bottom of the frame.
      • Lay the top of the board down and push it into its recess.
      댓글 쓰기
    14. Google Pixel 8 Pro Logic Board Replacement, Set the logic board down: 58 단계, 이미지 1개 중 1개
      • Flip the logic board over and lay it down on a soft, clean surface such as a towel to prevent damaging it.
      댓글 쓰기
    15. Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 59 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 59 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Disconnect the antenna cable: 59 단계, 이미지 3개 중 3개
      • Insert one arm of a pair of angled tweezers under the metal neck of the white antenna cable coaxial connector, located on the bottom of the logic board.
      댓글 쓰기
    16. Google Pixel 8 Pro Logic Board Replacement, Remove the antenna cable: 60 단계, 이미지 3개 중 1개 Google Pixel 8 Pro Logic Board Replacement, Remove the antenna cable: 60 단계, 이미지 3개 중 2개 Google Pixel 8 Pro Logic Board Replacement, Remove the antenna cable: 60 단계, 이미지 3개 중 3개
      • Gently pull the white antenna cable out of its clips on the bottom of the logic board.
      • Remove the antenna cable.
      • During reassembly, use the point of a spudger to gently push the cable back into its clips.
      댓글 쓰기
    17. Google Pixel 8 Pro Logic Board Replacement, You're left with the logic board: 61 단계, 이미지 2개 중 1개 Google Pixel 8 Pro Logic Board Replacement, You're left with the logic board: 61 단계, 이미지 2개 중 2개
      • You're left with the logic board.
      댓글 쓰기
결론
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
197,298 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 37,772개를 작성함
6가이드 댓글
I need an unlocked pixel 8 pro logic board where can I get one? Thank you so much Brian Purvis
brianpurvis5@gmail.com
Brian Purvis - 답글 공유
Hi, I can't see 5g antenna and cable in my 8 pro. Is it a common thing? Does it mean the 5g is built-in the T3 CPU? Please advise. Many thanks in advance.
MSP - 답글 공유
Hi! It's possible you don't have the mmWave version of the Pixel 8 Pro. As the introduction and step 24 state, you can still use this guide if you have the non-mmWave version, just skip the steps mentioning the mmWave antenna and cable.
Spencer Day - 답글 공유
Hello, I can't find any information on how to replace the power/ volume button assembly?
Lurker - 답글 공유
Hi
I want to know where
RF test point on the pixel 8 pro
Think you
Bouazza Cherif Abdelmoumene - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 150
지난 30일: 576
전체 시간: 11,432
