주요 콘텐츠로 건너뛰기
Apple의 iBook 노트북 라인은 소비자 및 교육 시장을 겨냥한 제품이었습니다. iBook 라인은 iBook G3 Clamshell, G3 12", G3 14", G4 12", 그리고 G4 14"로 구성되어 있습니다.
832 질문 전체 보기
Changing parts from one to another?
Hello, I wonder about the possibilities to use parts from iBook 12 inch LCD on the models G3 and G4. Parts as hard drive, battery, keyboard and well there must be more parts changeable? I'm thinking about buying used parts!
Thankful for answers.
Dick.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
The LCD panel (But not the assembly) can be used in either computer, the batteries are also cross compatible, As is the hard drive, Keyboard, And charger. The logic boards, RAM, and Optical drives however, are not interchangeable.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
These parts can be swapped between the 12" iBook G3 and the G4
SCREEN ASSY:
- LCD panel
- front bezel (inscription wont match)
- hinges
- back cover (with Apple logo) color wont match
- inverter board
- display latch mechanism
NB: cables CAN'T be swapped (connectors wont match on logic board).
Other compatibles parts:
- keyboard (please read rj713 comment)
- battery (color wont match)
- AC adapter
- hard drive (IDE 2'5" HD)
- bottom case screws and rubber feet (color wont match)
All other parts are model specific and can't be swapped:
- ram
- optical drive
- top case
- airport card
- logic board
- heat sink
- internal metal frame
- DC in board
- HD & optical drive cables
- fan
- etc.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
IIRC some keyboards won't work on some upper cases of the same model because of a groove in the top case is required for a proper fit. Ralph
thanks rj713, I edited my answer.
Thank you. Nice to know.
Dick.
댓글 달기
귀하의 답변을 추가하세요
Dick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 951
