S20+ with new ifixit battery not charging/not turning on
I bought a replacement battery from ifixit, a week ago, for my old samsung s20+. After carefully installing it, phone doesnt turn on at all and while charging phone only pulls about 1.7 watts.
So i tried the original battery to confirm the phone was working. and phone boots up without any issues and while charging it pulls 18-20watts easily.
I contacted ifixit support and they arranged another replacement battery but this battery also does the same thing. Not charging and phone doesnt turns on. Phone still works with the original battery.
So are there any hidden steps that i got to do during battery replacement process or do i just have bad luck and got 2 dead batteries?
좋은 질문입니까?
댓글 10개
@anas31761 there shoildn't be. What numbers are on yuor original battery, what numbers are on the iFixit battery. What is the exact SM- #### on your phone:
SM-G986B, SM-G986F, SM-G986U, SM-G986U1, SM-G986W, SM-G9860, SM-G986N?
oldturkey03 의
@oldturkey03
Phone model: SM-G986B/DS
Original battery model: EB-BG985ABY
iFixit battery model: EB-BG985ABY
iFixit part number: IF437-003-1
One thing i noticed is that both ifixit batteries are a little bit smaller in size physically than the original one.
Anas 의
That battery being a bit bigger can be caused by your other older battery expanding over time. With your main issue, have you tried different cables and making sure the charging plug is clear and not shorted out in any ways?
Infiniti 의
@infiniti_dev yeah i did try different cables. original battery works with all of the cables but ifixit batteries doesnt work properly. i mean both of them takes about 1.8w while plugged in when the original battery takes 18-20w.
Charging plug is clear ofcourse otherwise original battery would also not work
Anas 의
Yea, my best guess is you have a faulty battery, or there is a issue with your battery controller wich I doubt as your original battery works
Infiniti 의
댓글 5개 더보기
