주요 콘텐츠로 건너뛰기
The Backbone One is a mobile game controller for the iPhone. It was released in October, 2020.
A bug(living creature kind) got in my backbone
My left trigger and joy stick started acting funny, like they were constantly being pressed. Decided to pop it open to see if there was any obvious problem. Nothing seems broken, but there was an actual insect inside.
If you open up the sides and put the controller face up, there is a little square ish piece of tape(?) inside the back half near the top. I'm assuming it's a little bit of padding to reduce noise from releasing the trigger. The insect was underneath that. It's big enough you can see it's bent and squished from the trigger hitting it. I'm guessing this kept the trigger slightly pressed. I got the insect out, but my left trigger won't work now. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Ironic, isn't it?
XD yep. Seems the insect wasnt the problem though
댓글 달기
답변 1개
Honestly, I'd recommend replacing the trigger. There's a guide here, but I have no idea where to get replacement parts from. Maybe check ebay? Otherwise, you might be able to send it in to Backbone for repair.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
J Dex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 102
