주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
263 질문 전체 보기
My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
댓글 달기
답변 13개
가장 유용한 답변
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
i might try it
댓글 달기
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Oh yeah and what door do u mean
댓글 달기
well mine is a used one and it wont show
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I'm having the same problem :(
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
whats a clothing tag?
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
this is the only one here that helped me
Did yours have blended pins or was it just dirty?
댓글 달기
Try spray compressed air in the slot. There may be dust bunnies inside.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hello, I am a YouTuber who has this same problem. As soon as I find a fix it will be uploaded on my channel here.
Hopefully, when and if I upload the video it will help you out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
What door?I don't see a door
댓글 달기
I have borrowed a dsi and simply blew into the game slot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I think DSI causes issues sometimes in reading games. You have to try it again and again and hopefully, it will help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
it could be dust in the slot. try using a cotton swab and rubbing alcohol in the slot. if that does not work, take it to a repair shop or if you know how to repair it, buy a replacement game card slot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
One possible solution is to clean the contacts on both the game cartridge and the DSi console using a soft, dry cloth. This can help remove any dirt or debris that may be interfering with the connection.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
gaynordante 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 59
30일 전: 255
전체 시간: 39,420
