My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
좋은 질문 입니까?
좋은 질문 입니까?
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
해당 답변은 도움이 되었습니까?
i might try it
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
해당 답변은 도움이 되었습니까?
Oh yeah and what door do u mean
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
해당 답변은 도움이 되었습니까?
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
해당 답변은 도움이 되었습니까?
whats a clothing tag?
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
this is the only one here that helped me
Did yours have blended pins or was it just dirty?
Try spray compressed air in the slot. There may be dust bunnies inside.
해당 답변은 도움이 되었습니까?
it could be dust in the slot. try using a cotton swab and rubbing alcohol in the slot. if that does not work, take it to a repair shop or if you know how to repair it, buy a replacement game card slot.
해당 답변은 도움이 되었습니까?
24 시간 전: 10
7일 전: 61
30일 전: 257
전체 시간: 39,422
댓글 1개
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
Celine 의
