주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Will restore erase all of my music?
If you restore your ipod will it erase all of your music on the ipod? and if so, do you have to restore it? thanks heaaaaaps tho!!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Yes it will. If you have to do a restore, depends what's wrong with your iPod. The trick would be to either have it backed up before ;) or get a USB to ZIF adapter, remove your hard drive and copy your files with some of the freeware that is out there (depends on your OS) to your computer. Then restore your iPod and reload the music. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If you want to get back your erase all of your music. Well Lots of iPod music recovery software are available in the market. But reason is that how to recovers and restore my erase or deleted Files. I used one the best iPod music recovery this software very user friendly and no need technical experience. It can easy to use the software. Kernel Recovery for iPod software recovers all erase or corrupt music very small minutes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Really Kernel for iPod Data Recovery Tool is more advance or effective software. It can quickly & easily recover all lost, corrupted, accidentally deleted audio and videos song. The free demo version also available. click here :
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes it will. If you restore your ipod, it will erase all of your music on the ipod. But you don't need to worry about that. Only if you sync the music files to iTunes, the problem that how to recover music from iPod seems simple after you restore your iPod. You can use Data Recovery software to help you restore music files. It can recover all the music files in a few minutes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Renee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 16,295
