주요 콘텐츠로 건너뛰기
로지텍 MX Master 3S 무선 마우스 수리 및 분해 정보입니다. 2022년에 출시되었으며 모델 번호 MR0077, 부품 번호 910-006557, 910-006558 또는 910-006556으로 식별됩니다. 출시 당시 캐나다에서 판매된 그라파이트 버전의 경우 810- 008296처럼 다른 지역 또는 모델 버전에는 약간 다른 부품 번호가 있습니다.
Solid Red LED with no connection to the target
My MX Master 3S always has a solid red LED on it. After every power on and off, I can see a green LED come up. Below, I can see the mouse in pairing mode, and it appears on my laptop as well. But then, after 1 minute, it turns to solid red, and I cannot see it anymore on my laptop.
Could this be a loose connection? Or does it require a battery replacement? I have a 2S and 3, all of which show that they are charging by blinking LEDs in both mice, but for my 3S, it just shows a solid red even when it is being charged. I have already charged it for 3 hours, but the same behaviour.
I have already changed my dongle to the universal bolt
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Thank you very much @jayeff for your reply.
A very stupid question, so I just take out the battery and check the voltage right away right? And it should be around 3.8V? It won't matter on the state of charge within the battery.
@peekabooboo
You said that you have already charged it for 3 hours so after this amount of time it would be very close to being fully charged so the voltage should be at least 3.8V.
Understood. Thank you.
I will check this and come back here just in case and follow the guide you have attached. Thank you very much
댓글 달기
답변 1개
가장 유용한 답변
Hi @peekabooboo
If you have a DMM (digital multimeter) check the voltage of the battery in the mouse to see if it is OK or not i.e. approx 3.8V DC.
Here's the ifixit Logitech MX Master 3S 배터리 교체 guide that may help.
If the battery is faulty ifixit sells a battery for the mouse (see guide) or search online for 533-000205 to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hello,
I checked and it has 4.11V
댓글 달기
답변을 추가하세요
Peekabooboo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 49
전체 시간: 452
