주요 콘텐츠로 건너뛰기
Apple의 M2 SoC가 탑재된 2022년형 13인치 MacBook Air에 대한 수리 안내서, 지원 및 문제 해결 정보입니다. 2022년 7월 15일에 출시되었으며 모델 번호 A2681로 식별됩니다.
Display flicker, no keyboard/trackpad?
Wanted to post this question here—I've had a few cases involving different A2681 where the trackpad and keyboard both become non-functional and the display continues to power off/on randomly, making it very hard to use. I've also noticed that the display flicker on the login screen seems to respond (though somewhat randomly) when you tap the power button. Is this a known issue with these models? Has anyone experienced something similar, and if so, how did you repair it? Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I had a few, one had liquid damage on the logic board after a good clean and replace a few bad SMD devices I got it working again. A different system had a bad T-CON board had to replace the display assembly, the third one seemed to respond to a OS update and an SMC reset.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Zach 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 91
