주요 콘텐츠로 건너뛰기
Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
How to perform decalcification forcefully on Jura F50.
My water flow is very weak and I think it's due to no decalcination cycle in a long time. In instruction it says to wait for message and only then you can do it. There is no maintenance menu for separate de-scaling.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
@vladyslavm48017 here are the DESCALING instructions right from the manual Chapter 18:
and in writing just in case the images are not good enough :-)
Descaling
Again, these are the DESCALING instructions, NOT the cleaning instructions
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you all for help. My translated manual didn't have a line about screen off.
댓글 달기
가장 유용한 답변
(0) Important prerequisite: machine is in stand-by, filter status off.
(1) Press the rinse button for four seconds
(2) Now empty the drip tray as requested, it must be outside for at least 5 seconds.
(3) Dissolve the descaling agent (Ammonium sulfatic acid is best) and pour it into the tank. Place a larger container under the steam outlet.
(4) Turn on the steam tap
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
It is normal cleaning instruction, it will not start de-scaling process, that I want to do.
No, this is for descaling. Perhaps I should write "maintanance button", nor "rinse button". Anyway, this is the button with six drops on it.
댓글 달기
I’ve used CLR Lime & Rust cleaner and making sure to fully rinse out the reservoir and lines. You may need to use a loadable pod to fake out the machine.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
How do I start decalcination on this coffee machine? There is no button for this or menu button. I can only hope that message that it needs decalcination pop-up. I have cleaning powder for decalcification.
I need to do de-scaling. Not ordinary cleaning.
@vladyslavm48017 - I don’t know this exact system, cleaning is just the term used by this maker as there is really no difference between cleaning and de-scaling (removing lime build up) is just the chemical aspect of cleaning using more effective solutions than water alone.
댓글 달기
Cu expresorul oprit, țineți apăsat pe butonul de clătire, până apare mesajul de curățare a tavitei,...in acel moment, incepe propriu zis procedeul de decalcifiere...care are durata de circa 40 minute....
Spor...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vladyslav Mrynskyi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 70
전체 시간: 981
