Heating coil element is rusted
So, I've taken apart my Farberware FCP412 coffee pot and found the entire heating coil/element is rusted badly. Can the heating element be replaced or shall I just trash it and buy a new coffee percolator?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개:
@michele1l don't bin it yet :-) Let's see what you got going on there. It should be replaceable. Post some good pictures of all that stuff with your Question. That way we can see what you see. 기존 질문에 이미지 추가하기
@oldturkey03
Thanks, added image
@michele1l yeah, looks a little crunchy :-) I wonder if it still works. Rust in itself should not spell the death of it. Do you have a multimeter? If so set it to Ohms and measure the resistance of the heating coil. If this is a 110V percolator the resistance should be about 12ohms.
Thank you for your help!
It doesn't heat enough to make it "percolate" up the tube, but now it starts to heat up and shuts off. I ordered a replacement thermostat before I actually took it apart to see that the old thermostat is pretty immaculate but heat element is corroded. Yeah, I'm getting a new pot. Appreciate your help tho 👍
댓글 달기
