주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for your Philips TV.
Philips TP Vision 50PUS7805
I have sound all the time but the picture comes and goes. I had horizontal lines along the bottom few inches of the tv for the last year or more.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@babarmirza since you said the pictures comes and goes, that could actually be the backlight turning on and off due to failing and overheating backlight strips. Let us know how long the screen stays black. If it is long enough, then you could try and shine a flashlight beam at an angle against the screen. If you can still make out your images then you know it is the backlight strips.
It is also possible that this is a bad panel. Based on the horizontal stripes. Horizontal stripes are always caused by a failed GATE driver which are considered part of the panel.
If you can, post some images of what your TV displays while the screen is working. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Babar Mirza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 67
