์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
Apple's sixth-generation smartwatch, with optional cellular connectivity, released September 18, 2020. Model A2376, 44ย mm.
20 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
New battery wonโ€™t charge
New battery ๐Ÿชซ is showing 1% and the display symbol is a red bolt indicator. Watch charges fine with old battery. Watch reset just fine but it will not charge properly. Constant rebooting on the new dead battery.
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ
Similar problem here: new battery. Watch still doesn't show signs of life. Gets hot while charging. Nothing on display after trying all button combination.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
When you connect the puck onto the watch does it even respond?
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 2๊ฐœ:
Yes the red circle bolt turns on
@joemech83 - Jump to Step 14 in this guide Apple Watch Series 6 ๋ฐฐํ„ฐ๋ฆฌ ๊ต์ฒด double check the connection, is the connection firm, could one of the contacts or the cable damaged? Otherwise youโ€™ll need to get a replacement battery.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Joemech83 ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 1
์ง€๋‚œ 7์ผ: 1
์ง€๋‚œ 30์ผ: 2
์ „์ฒด ์‹œ๊ฐ„: 36
